Results 1 to 8 of 8
Thread: Safety wiring question
    4
    How can I safety wire the front axle and pinch bolts on my Ducati monster 750? The pinch bolts and axle are all recessed into the fork legs and I don't see any way to wire them. Would RTV be OK on these bolts or is there some trick Im missing? If anyone has experience with wiring an air cooled duc your help would be greatly appreciated. Thanks!
    481
    You'll probably have to drill through the fork bottom into the bolts.
    pm sent
    Dec 2005
    142
    Where do you live? I'm sure you can find a racer that lives near by to come over and do a quick overview of everything on the bike for you.
    4
    I am in the Springs. I could make something work if I drilled the forks. I was hoping I wouldn't have to but, if that's what it takes! Everything else is wired I just need an example to work from on this.
    here is a pic of what i did with the recessed caliper mount bolt on my 748, hope this helps
    Idaho Springs
    50
    man glad i gound this. assuming that since ray didnt disagree this is still acceptable.
    Feb 2009
    Parker
    527
    While on the topic, anyone have pics of levers wired? I got the banjo bolts done, would like to see a set of levers if possible!
  1. Wiring Harness?
    By sneeky in forum Rules & Tech
    Last Post: June 25th, 2013, 11:06 PM
  2. Wiring harness 03-04 R6
    By Dodd in forum Wanted!
    Last Post: April 9th, 2013, 05:44 PM
  3. safety wiring drill bits?
    By Smitty in forum General Discussion
    Last Post: July 4th, 2012, 12:47 PM
  4. Safety Wire Question
    By peteyt328 in forum Rules & Tech
    Last Post: March 26th, 2010, 06:28 AM
  5. Safety Question Regarding PMP...
    By d_mob in forum General Discussion
    Last Post: June 25th, 2008, 08:17 AM
