Results 1 to 9 of 9
Thread: Bike Won't Start
    Sep 2007
    Littleton
    24
    Bike Won't Start
    I have an '05 GSXR 600. The bike was running at idle last week and died when we gave it throttle. It hasn't started since. I've replaced the old gas, charged the battery, and checked the plugs. It cranks just fine but won't fire up. The red light on the gauge is flashing and in the temp spot it says "FI". Is my fuel pump dead already? Would a failed water pump cause the bike to not start? Any ideas?
    glenngsxr
    Find the procedure to check which fault code you have and get back to the board. Glenn #62
    282
    FI is the the fuel injection code I believe. Did you pull the tank to get rid of the old gas? If so I would check under the tank for a loose plug on the injection rail. Also when you first turn on the key does the fuel pump fire up?
    you just had that bike completely apart. are you sure you connected everything correctly when you put it back together?
    509
    did it have race gas in it?
    Benny Tozzi #78
    Tri City Cycle
    Check out Dave@SingleTrackMind for your suspension needs!
    www.fixmybike.com
    www.getwellclarkie.com
    Sep 2007
    Littleton
    24
    I got the dealer switch from work and it's showing me C23. I think that's the tip over sensor. Any idea on the fix?
    Sep 2007
    Littleton
    24
    I messed around with all the connectors and what not under the seat and was able to get it to start for a minute. Then is died and gave me the same error. I do believe its the TOS. I'm not sure what it looks like or what I have to do. Is that something you normally take off of a race bike?
    Timmy, Did you put that tip over switch back in upside down or something?
    Sep 2007
    Littleton
    24
    Turned out to be the TOS. Thanks for the assistance.
  1. GSXR won't start
    By CaneZach in forum Rules & Tech
    Last Post: April 30th, 2012, 10:13 AM
  2. Bike won't start
    By SOCAL4LIFE!! in forum Rules & Tech
    Last Post: April 29th, 2011, 09:56 AM
  3. Better start looking for rains
    By vort3xr6 in forum General Discussion
    Last Post: April 29th, 2010, 09:07 AM
  4. PR- Start Something- Volunteer Here
    By Wild Cheetah 612 in forum General Discussion
    Last Post: July 14th, 2009, 11:02 AM
  5. CBR F3 wont start -help!
    By Mforza in forum Wanted!
    Last Post: January 18th, 2009, 10:26 PM
