1. Kids are allowed to be on wheels during lunch and before the track goes hot in the mornings.
2. 2.12.A. Internal modifications of the OEM radiator may be made, as long as the external materials and dimensions remain the same. - I propose to change the supersport rule to allow for larger or aftermarket radiators in supersport racing category. This is more a safety and rider longevity concern, if the bikes stays cooler, it won't blow up on the track and cause a mess, accident, or lengthy clean up process.
3. Qualifying for grid positions in ALL supersport and superbike races.
4. Grid positions be staggered rather than each row in a straight line giving little to no advantage/dis-advantage to riders based on points positions or qualifying positions.
5. Award 1 championship point for qualifying on pole position per category.
6. 8.5.D. Colors - all Expert competitors will use black numbers on a white background. Numbers must be approximately 6” high and 1” wide, of standard block lettering with no shading or outlining. Novice competitors will use black numbers as specified above, but the numbers shall be on a yellow background. - For this I propose a change to allow in the rule book for numbers to be approved if outlined in a color of the riders choice. Also allow for numbers color to be other than black or white, but must be approved by the VP of rules and tech before being used in a race setting. (half our club in the last 7 years have had outlines, different color numbers, and has always been let slide)
