Results 1 to 2 of 2
Thread: 1999-2002 YZF-R6 Front & Rear Wheel Set; 1998-2002 YZF-R6 (front only) $125/set
    Member Novice
    May 2013
    Boulder
    45
    Dirty but in good condition. Straight, no damage. Comes with rear brake rotor, rear sprocket with carrier, cush drive rubber spacers, front rotors. Front tire is completely dry rotted, rear tire has seen some burn outs so is on it's last leg but does have some rubber left. I will bead blast both of the rotors for $25. The rotors are straight and are well within spec thickness. The cush driver spacers are in great shape. I have several 530 sprockets you can have.
    FRONT will fit 1998 to 2002 R1 AND 1999 to 2002 R6.
    Rear will fit 1999 to 2002 R6.
    Member Novice
    May 2013
    Boulder
    45
    Sold
Tags for this Thread
