After much thought, I've decided to sell my tire changer. I have a Hofmann Monty 455. Offered at $3000.
http://www.motorcyclecarbs.com/kl/catalog/2003/020.pdf
* This model is designed for motorcycle, ATV, light car and truck wheels.
* The Monty 455 is designed to change all brands of motorcycle wheels, including tires in the difficult Harley Davidson belt drive rims. Standard Clamping jaws allow for changing light car and truck wheels as well.
* Dual clamping cylinders assure proper clamping pressure for all four jaws. Powerful, yet gentle clamping pressure is adjustable so even the most delicate wheels can be clamped without damage.
Specifications
Rim Clamping Diameter 10 to 21 inches
Maximum Tire Diameter 40 inches (101.6 cm)
Bead Breaker Range 1.3 to 13.0 inches
Bead breaking Power 5,954 lbs (2,700 kg)
Shipping Weight 419 lbs (186 kg)
Power Requirement 115 V, 1 phase, 50/60 hz
