Results 1 to 9 of 9
Thread: Quick shift sensor difference?
    Member Amateur Islandermyk's Avatar
    Nov 2009
    Aurora
    97
    Does anyone know the difference between the dynojet 4-102 sensor and a 4-114 sensor? I got on ebay and bought a 4-102 sensor and hooked it up to my PCV and no quickshifting.
    Thanks in advance!
    ... itchy... when it bites....
    Jun 2012
    68
    Looks like one is for the PCIIIUSB and one is for the PCV.
    http://www.powercommander.com/powerc...k_shifter.aspx
    MRA #760
    Nov 2009
    Aurora
    97
    Quote Originally Posted by blaircsf View Post
    I'm trying to figure out what makes these sensors different from each other, I guess...?
    ... so if I were to splice the PC3 QS sensor and mount the QS sensor to the PCV it should technically work right?
    Nov 2009
    Aurora
    97
    Okay.. I think I found "some" answers to my question.
    "Open" and "Close" loops... I think that's what separates them, right?
    Now to try and figure out if the QS sensor 4-114 is an Open or Close....
    Sep 2015
    Littleton, CO
    81
    doesn't seem to be much life in this forum now that the season is over....
    I have a PCV push sensor you could try and buy if you wanted
    Jared Dear - MRA #48
    Quik Cycles, Sol Performance, Pirelli tires
    Nov 2009
    Aurora
    97
    Quote Originally Posted by Redline View Post
    Yea.... It seems like that... but still was worth shooting out there.
    I might need a pull sensor if the set up I got doesn't work... we'll see what happens tomorrow or Thursday, lol!
    Thanks for chiming in!
    Nov 2009
    Aurora
    97
    I just found out that with a PCV it doesn't matter if it is a open or closed style sensor. You can program it through your PCV to accept what ever style you got.
    I got the QEM understanding that the PCV cannot handle the 8 fuel injectors (which only controls the lower injectors) on my bike so a QEM is needed (to control the upper injectors).
    Life is good... if not better
    Nov 2009
    Aurora
    97
    I just PM'd you... A friend of mine might be interested in you QS sensor.
    Sep 2015
    Littleton, CO
    81
    sent you a text. let me know
