Thread: 2009 CBR600rr parts
    Aug 2013
    Golden
    8
    2009 CBR600rr parts
    stock parts off of a 2009 CBR600rr I no longer have
    * rear wheel
    * rear rotor
    * rear sprocket
    * cushdrive assembly
    * Rear wheel axle, spacers, caliper bracket
    * swingarm
    * shock
    * swingarm axle
    * pillion peg hangers w/ footpegs
    * subframe
    * tail plastic
    * seat pads (pax is torn a little on the corner)
    * front fender
    make an offer if there's something you can use
    would trade for 03-05 R6 parts
    Aug 2013
    Golden
    8
    almost forgot: I should have the stock rearsets somewhere, too.
    Mar 2007
    need that subframe if still available.
    mike- (9 seven oh, 3three3, zerofourseven2)
    Sep 2010
    Thornton
    6
    Do u have the gear shift linkage.....What I resally need is the vertical arm that connects everything together.......need it desperately if u have ill come get.
