ZX6R part out
I blew the engine up on my race bike last weekend and am now parting it out. The bike is an 03, but 90% of the parts I am selling below have been purchased in the past 2 years and most of them new. The majority of these parts will fit most kawis. Feel free to call/text/email me for pictures or more information about parts... I know A LOT about ZX6Rs and can most likely answer your fitment questions.
Suspension:
07/08 zx6r Ohlins 25mm full internal forks w/ 1.0kg springs. Best for 185-200lb rider, a little stiff for lighter guys but usable if you like that. Will Fit all year ZX6Rs. Purchased 2013, serviced March 2014, fork seals are perfect -$900
Matris M05R Rear Shock w/ extra spring. Set up for 175-200lb rider, extra spring for 150-175lb rider. Hydraulic preload adjustment, High and Low Comp., remote res. Will fit most years Zx6R,Serviced March 2014 -$600
Brakes:
Brembo Aprilia RSV master -$125
2014 Hel braded lines -$50
2011 Zx6r Nissin Calipers w/ Performance Friction 07compound pads - $150
Braking 300mm SK2 Rotors fit 03-2012 zx6r - $250
Stock ZX6R rotors 03-2012 zx6r - $80
Lightweight drilled out rear rotor (all years zx6r) - $30
05/06 rear brake with line and master - $30
Stock lever sets - $10 each
Control:
08 Tach w/ converter - $175
03 Tach - $30
GPR v4 stabilizer - $300
AMB wired transponder - $350
Woodcraft rearsets - $150
Annitori Gen2 Quick Shifter - $200
Motion-Pro Quick turn throttle - $75
Stock clip-ons (fit all 50mm forks) - $20
03 Frame + tail 06 swing arm + linkage - $200
03 Blown Race Engine - $200
03/04 throttle bodies with upgraded 06 injectors - $50
03/04 intake tube and race fairing stay - $40
03/04 airbox - $20
Race ECU - $65
07 Voltage Regulator (FH016AA) If your zx6r does not have this model (07/08) it seriously needs to - $25 each
Factory Pro Shift Star - $75
05 Radiator with Samco hoses and Race cap to fit 03/04. - $150
Woodcraft cover with new slider - $40
Wheels:
03 rear wheel (black) straight - $30
05+ rear wheel (silver) straight - $150
05+ front wheel (black) straight - $100
05+ front axle - $15
05+ rear axle -$15
03/04 rear axle - $10 each
Michelin VA 120/17 DOT race tire purchased new May 31,2015. 4 sprint races - $100
Other:
RK GB520GXW Gold Chain w/ extra links + 14/45 gearing $75
Almost completely new sunstar 45 rear steel sprocket 520 - $20
Almost completely new driven 44 rear aluminum sprocket 520 - $20
15t counter sprocket 520 - $10
14t counter sprocket 520 - $10
Hindle Ti Race exhaust - $100
BMC race air intake filter WITH CLEANER AND OIL - $ 40
03 tank no dents w/ fuel pump - $200
03 race body work needs new paint - $100
Plastic green frame sliders - $15
Woodcraft Right side frame slider with extra puck - $15
If you don't see something here that you need I most likely have it!
Does the rear 05+ wheel come with a sprocket, cush drives, and rotor? If so I'll take it.
Just the wheel and the crush drive . I have a pending sale on the wheels.
UPDATE:
Suspension:
Brakes:
Brembo Aprilia RSV master -SOLD
2014 Hel braded lines -SOLD
Braking 300mm SK2 Rotors fit 03-2012 zx6r - SOLD
Control:
08 Tach - $125
03 Tach - $30
Annitori Gen2 Quick Shifter (fits all years zx6r, 04+ zx10r, all zx14s) - SOLD
Motion-Pro Quick turn throttle - SOLD
03 Frame + tail 06 swing arm + linkage (salvage title)- $200
03/04 airbox - $20
Race ECU - $65
07 Voltage Regulator (FH016AA) If your zx6r does not have this model (07/0 it seriously needs to - $25 (one left)
Wheels:
Marchesini 16.5 rear rim (fits 03/04) can still race pirelli tires!! - $100
05+ rear wheel (silver) straight - $150 (pending)
05+ front wheel (black) straight - $100 (pending)
05+ rear axle -$15
03/04 rear axle - SOLD
Other:
Almost completely new sunstar 45 rear steel sprocket 520 - SOLD
Driven 44 rear aluminum sprocket 520 - $20
14t counter sprocket 520 - SOLD
BMC race air filter WITH CLEANER AND OIL - $ 40
03 tank no dents w/ fuel pump - SOLD
07 front hugger with crack - $25
Front and rear stands - SOLD
Wheel balancing stand - SOLD
T2 TIRE WARMERS - SOLD
AMB wired transponder w/ inline fuse - SOLD
