Senior Member
Amateur
2014 Lark 8.5' x 20' Trailer Black
For Sale:
2014 Lark 8.5' x 20' enclosed trailer. I had this built to spec last year and took delivery of it at the beginning of May. I used it to race 6 rounds with the MRA. It has been towed just under 2000 miles total. It was stored inside until January 15, 2015 and has since been stored outside. There are a lot of upgrades made to this trailer and it was over $15,500 new. It is in great shape. The only thing worth mention is some minor hail damage that is just on the rear door. I tried to get pictures of it but it didn't come out great. With the current set up I hauled 4 bikes and their spares and all the gear we needed for the weekend. I've never had a car in it, but I'm pretty sure it would fit. Fender to fender inside is 6'11" It has a lot of lights and working on something inside or outside at night is not a problem. AC and heating element work great. $13,500
See more pictures here:
http://denver.craigslist.org/for/4966976641.html
Exterior:
- Hidden dove tail
- Screwless exterior
- Upgraded to thicker aluminum siding
- (2) 7500 pound axles
- Torque arm suspension
- LED lights all around
- 2 exterior Halogen work lights flush mounted, very bright
- Load light in rear
- Extra tube brace added on tongue
- 3' x 2' x 2.5' generator box on tongue with extra plug in on side. Top and front openings.
- Electric brakes
- Breakaway switch
- 18' matching black roll out awning
- 2 5/16" ball
- Hand crank landing gear
- Comes with 3 matching locks
- 7 pin flat electrical connector
- RV handle on side door
- Spare tire
Interior:
- Rubber coin floors, ramp, and lip ramp
- Vinyl walls and ceiling
- Insulated ceiling and walls
- AC unit with heating element
- (2) 2 bulb florescent lights corner mounted
- Separate dome light
- Switches for all lighting functions
- Breaker box
- Built in step behind side door
- 3' side door
- (2) Pitbull trailer restraint base plates
- Spring assist rear door with dual latch
- 6 current tie down points installed, more can be added, 2 additional uninstalled included.
- 20' 220v 4 wire cord into breaker box. There is a covered hole in the floor so it can be run outside.
Senior Member
Amateur
Still selling this trailer. I should have it out at the race school if anyone wants to come by and see it.
Senior Member
Amateur
$11,900 or you can take over the payments. Mine are currently $270/month
