2003 ZX6R PART OUT
Info and parts listed listed below. Please post up any offers you have for parts and or make offer for everything.
FOLLOW LINK TO FACEBOOK FOR PICTURES:
https://www.facebook.com/louden.davi...9220878&type=3
The motorcycle does have top end motor damage due to a valve dropping into cylinder number 4. It damaged the cylinder head, the cylinder and the piston. Bottom of the motor is in good condition with a nearly new transmission that was installed last year. Motor has Kit cams, and manual cam chain tensioner. Kit racing harness and ECU. Also motor has factory pro case covers
Currently the bike has
Bridgestone VO1 slicks with good life left on them
Both Wheels are straight
Front rotors are in good condition
Recently rebuilt calipers with decent brake pads let
Steel braided brake lines
2008 zx6 Front brake Master Cylinder
Stock bars and levers in good condition
Triple is straight and in fair condition minus some scratches.
Front Forks in good condition with valves, 1.0 springs, and recently serviced with ohlins fork fluid
Body work has some scratches and is not the highest quality, but they work with clear windscreen
Gas tank is has some damage, but works fine with screw of gas cap and good fuel pump
Racing front fairing stay from yoyodyne
Frame was powder coated a few years ago including swing arm so all bearings were replaced three years ago and all seem to be in good condition.
D.I.D. EVO chain with renthal sprocket (rear slightly worn at this point)
Rear Caliper and Brake Master are in working order with slotted rear brake pads ( for easy removal/install of rear tire)
Rear brake rotor has been lightened and in good working order
Rear shock (in picture is an ohlins, but it has been removed) Planning on reusing this part for another build
Full Arrow Titanium exhaust in (fair condition has some scratches on the can makes great power and has mounted for better performance/usability)
Over sized radiator
NEW Woodcraft frame sliders
Rear sets (I believe they are Attach but not sure)
Ohlins Steering damper from frame mount with fork tube clamp (not show in photo, but its about 1 year old in good condition)
Seat Slight scuff on side, but works fine
Rectifier works fine
Also have several spares including all the parts need to rebuild the motor that you'll see in other photo that include:
CYLINDER HEAD WITH VALVES
TWO CYLINDERS
TWO SETS OF PISTONS WITH RINGS
VALVE SPRINGS
VALVE CUPS
CYLINDER HEAD GASKETS AND OTHER GASKETS NEW IN PACKAGE.
VALVE COVER
NEW CLEAR WINDSCREENS (TWO)
SEVERAL NEW CASE COVER SLIDERS
BRAKE RESERVOIRS
THROTTLE TUBE WITH CABLES
NEW RENTHAL REAR SPROCKET
OTHER SPROCKETS AS WELL
BENT FAIR STAY
SPARE FRONT FENDER
STOCK REARSETS
SEVERAL BARS AND LEVERS
FUEL PUMP (WORKING LAST IT WAS USED)
NEW EBC BRAKE PADS
GAUGE CLUSTER
SPARE SPARK PLUGS SOME NEW SOME USED
REAR CUSH DRIVE
GAUGE CLUSTER
THROTTLE BODIES
FRONT BRAKE ROTORS
PARTIAL AIR INTAKE AND AIR DUCT SEAL
FRONT FENDER
Might have another box of parts floating around with more stock parts including wire harness, but I'll have to see if I can find it.
MAKE OFFERS BELOW
