Just got in an 06 GSXR 600 Track Bike (Thank You Bob) That's got some goods on it. 6754 mi. See anything or need something you don't see shoot me an email Chidadog@gmail.com I've probably got it.
Stock Stuff
Seat………….30
Ram Air Tubes…………….50
Gas Tank Blue………SOLD...but have others
Fuel Pump…………………65
Ignition w/key and cap …………..100
Clip Ons………………….40 ea
Triple Tree…………………100
Forks......................200
Radiator.................130
Clutch Perch………………….15
Clutch Lever..................10
Front Brake Master………………75
Front Brake Lever……..15
Rear Brake Master………………20
Stock Front and Rear Brake Lines…………5
Rear Rotor……………30
Front Rotor………….50 ea
Front Calipers………………..20/pc
Rear Calipers…………………15
Front Rim ……………………..200
Rear Rim ………………………150
Carrier/Hub (750) …………30
Front Axle…….15
Rear Axle………15
Front Spacer………10
Rear Spacers………..15
Gauge Cluster……………..150
Fairing Stay..............50
Front Short Harness…………….40
Rear Short Harness…………….20
Stock Headers………………..60
Rear Muffler……………….50
Left Accessory High/Low Beam……………25
Right Accessory Starter…………35
Front Seat……………….25
Swingarm………………..45
Swingarm w/broken spool mount……..25
SubFrame with repaired but straight box………………….150
SubFrame Rails L&R……60
Battery Tray……….20
Black Undertail ……..10
Shock……………25
Links……………25
Kickstand………………….40
Stock Rearsets…………..45 ea
Shifter Assembly ……….35
Speed sensors……45
Turn Signal Relay…..20
Tank Side Covers..............20 ea
Front Fenders...........45
Rear Huggers........20
THE GOOD STUFF which is ALL NEW the bike was never ridden
Bazzaz TC/ZFI......SOLD
Bazzaz TC/Map Switch....SOLD
Brembo 19x18 slight bent lever ......210
Brembo Reservoir........45
Brembo HP Full Floating Rotors 310mm 70.1517-B (used)....450
Galfer Rear Rotor………….80
ASV Levers Black Shorty Silver Adjusters F&R…..SOLD
CRG SuperSport Clutch.......120 (Used)
Driven Gold Spools....25
Driven Gold Swingarm Blocks/Adjusters with Sliders......SOLD
No Cut Sliders.......40
Front SS Double Lines...............60
Rear SS Line...................35
K&N Air Filter..........30
BMC Air Filter.........40
Ohlins 30mm Carts/Forks .....825
Ohlins Silver Fork Extenders.......175
Ohlins SU789 Mk 2 TTX Rear Shock Newest Model 1.0 Spring .......900
Ohlins Steering Stabilizer…………200
Scotts Steering Stabilizer New in Box.........350
Vortex Black V2 Rearsets w/folding levers……SOLD
Yoshimura EMPro........475
Yoshimura Cable and software..........250
Yoshimura STR-S Cams w/adjustable sprockets.........600
Ported and Polished Head Decked...........500
Woodcraft Right Side Case Protector.............SOLD
Woodcraft Left Side Stator Cover...............SOLD
Woodcraft Sliders……………SOLD
Woodcraft Clip Ons…………..SOLD
Vortex Black Gas Cap……………60
Ballistic 8 Cell Lio Battery (used)..........85
Motion Pro Revolver Throttle w/ Discs………..SOLD
Motion Pro Kill Switch…………SOLD
Akropovic Full TI CF Can (some cf broken on top) with CF hanger……….SOLD
Driven 45t Sprocket………….SOLD
Optimal Body SS tail...........325
Clear Windscreens……….30 ea
ChickenHawk Warmers Single Temp (used)...............275
NTEC Take Offs DOT 120 190/55 GPA complete sets...........150
3 Sets of Rains Michelin, Dunlop, Bridgestone……………150 ea
