Not sure if there is a market here locally but figured I'd put this stuff out there. If my prices are off, you won't offend me with an offer.
Front and rear. Gold 10 spoke marchesini's. These have not been down and are undamaged. $1500 obo.*
Set of Brembo rotors. These are the full floating race rotors and have titanium bolts. $350
Brembo clutch radial master cylinder from 1098. Complete with reservoir, clutch line, yoyodyne clutch slave cylinder, and CRG adjustable lever. $350
Ohlins steering damper with bracket/hardware from 1*98. SOLD
1098 Showa forks with Ohlins 25mm cartridges. $800
Brembo m4 monoblocs with new EBC extreme race pads $550
Termignoni race exhaust. This is the full 70mm system. Including 2 filters. $1250.
Complete 1*98 swing arm with hub and rear rotor. Came from race a teams 1098R with extra skid plate and bead welded on to protect in case of get off. $350. A nice upgrade to an 848 to run the forged marchesini's
DID ERV3 520 chain and Supersprox gearing. Including the sprocket carrier. 14,15,16t fronts and 47, 48t rears. All in good shape with a lot of life yet. $200
Sato type 2 rearsets with levers. Lowsided but still very solid and useable. $125
Sato frame and wheel sliders. $50
Stock 1098 gas tank. Small scuff on one side but otherwise very good condition. Including fuel pump and DP keyless gascap. $250
Dash with matching ignition (including carbon fiber ignition cover) with 2 keys. $350
Complete wire harness. $75
1098 air box with injectors. $100
ALOT more stuff not listed so feel free to ask.
seann137@gmail.com for pics
