Results 1 to 8 of 8
Thread: 06 GSXR 1000 A Bike Loaded Part Out Yosh, Brembo, Marchesin
    Feb 2013
    Royersford PA
    30
    Hey Gang
    I've got the A bike to the B bike that I'm parting. This is loaded. Short list..Marchesini, Brembo rotors, calips master, pads. Vortex LOCKING Black cap, rearsets, sprockets. M4 Full Ti Exhaust, Yoshimura Case guards, rearsets and UNAVAILABLE Complete Triple with 3 eccentrics on shafts. Bazzaz TC, Ohlins 25mm carts, stabilizer and rear su503 (46) Offset Swingarm Pivots etc...lots more so check back.
    YouTube Vid http://www.youtube.com/watch?v=IxSuj...layer_embedded
    Here it is......Get ready to grab something to drink and eat to get through it all. I'm sure I missed some stuff so whatever you need just ask.
    Stock Stuff
    Inner Cowls………………..35
    Ram Air Tubes…………….45
    Rear Black Cowl………………65
    Undertail…………..30
    Front Turns/Mirrors wires cut flush…………..50
    Gas Tank Black/Red left side dented…………..130
    Gas Tank Orange Right side dent………………………..150
    Small Tank Panels………….20
    Large Side Panels ……………15 ea
    Fuel Pump…………………65
    Rear Turn Signals………………..65
    Lock Set Ignition, Cap, Rear Lock…………..125
    Triple Tree…………………100
    Stock Damper………………25
    Clutch Lever with Perch………………….25
    Front Brake Master………………65
    Rear Brake Master………………10
    Stock Front and Rear Brake Lines…………10
    Rear Rotor……………40
    Front Calipers………………..40
    Rear Caliper…………………20
    Front Rim……………………..190
    Rear Rim………………………100 Have a BUNCH
    Gauge Clusters just ask…….120-160
    Front Short Harness…………….45
    Rear Short Harness…………….15
    Main Harness…………………….80
    ECU………………………………100
    Rectifier……………………….75
    Throttle Bodies……………85
    Stock Titanium Headers………………..85
    Air Box…………..20
    Front Seat……………….25
    Left Accessory High/Low Beam……………35
    Frame R Title………………1100 HAVE A FEW FRAMES JUST ASK
    Swingarm………………..45
    SubFrame………………….175
    Battery Tray………………….15
    Front Axle………………….15
    Rear Axle with Blocks………15
    Rear Spools……………….10
    Kickstand………………….40
    Radiator……………….140
    Oil cooler……………40
    Stock Motor………………1200 Have a few one is SS as well.
    Stock Exhaust complete…………..150
    THE GOOD STUFF
    SS Built Motor…………..1400
    Marchesini 17" Alloy F & R Rims w/ Carrier and NEW Vortex 43T Sprocket………….1300
    Flashed ECU……………………….160
    Race Tech Fork Internals ………………………400
    Ohlins 25mm Carts………………..600
    Ohlins SU503 Shock…………………….550
    Ohlins Steering Stabilizer……………190
    Brembo 19x18 Master…………….230
    Brembo 19 x 16 Master………….210
    Brembo HP Full Floating Rotors 310mm 70.1517-B ……………….450
    Brembo Front Mono Calipers…………………400
    Carbone Lorraine Pads C59 NEW Front Set…………100
    Galfer Pads Rear FD325G1370 NEW…………25
    Galfer SUPER BIKE SS Lines F……………..70
    Galfer Standard Black Standard Front Lines……..50
    Galfer 2-1 Black Front SS lines………………SOLD
    Galfer Rear SS Black Line……….40
    CRG Gold Shorty Brake Lever…………………..75
    Woodcraft Stator Cover……………90
    Woodcraft/CF Motosports Silver Rearsets………………200
    Vortex Black Rearsets………….200
    Vortex Black Spare heel plates L and R…………10 ea
    Vortex V3 Black Locking Gas Cap……………………85
    Vortex Rear Sprockets 42 43 44 46 51 etc… 20 ea New in package 30
    Vortex Front Sprocket 16T and 17T New IN Package……20
    DID Gold 520 ERV3 and 520 MV Chain………..40 ea
    Sun Star 42 Sprocket (Nice sprocket)………………40
    Braking Rear Wave Rotor………………65
    Yoshimura Case Savers L&R…………85
    Yoshimura Black Rearsets……………200
    YOSHIMURA ONE OFF RACE TRIPLE R-K720-UC and LC with 3 eccentrics…….1100
    Sliders…………..25
    Race Fairs not sure on make fairly clean 4 sets………………250 ea
    Zero Gravity Clear Windscreen…………40
    Zero Gravity DB Tint Windscreen Scuffed…………30
    Offset Swing Arm Pivots…………….200
    Sato 50 mm Clip Ons………..85
    Silver Clip Ons……………………..50
    Motion Pro Revolver Quick Turn Throttle with cams……………85
    Motion Pro Starter Switch whole wired harness………………30
    Dynojet PCIII……………………175
    Dynojet Ignition Module……………170
    Dynojet STANDALONE QS Push……200
    Bazzaz TC…………………….475
    Bazzaz Map Switch and TC Adjust…………90
    Factory Pro Velocity Stacks………………200
    BMC Race Air Filter Cleaned and Charged…………………45
    K&N Air Filter………………..40
    Frame Sliders…………………..20
    M4 Full Ti Exhaust Missing one flange………….275
    Boz Slip On Exhaust…………….175
    Dano’s Stand Alone QS……………200
    Ballistic 8 Cell Battery…………….85
    Carbon Fiber Ram Air Tubes………….120
    Carbon Fiber Chain Guard (2 piece)………50
    Carbon Fiber Shark Fin………………SOLD
    Shark Fin.............20
    Road Racing Forums/Free Natl Classifieds www.motorcycleroadracingforums.com MRRF
    Senior Member Expert DOUBLE A's Avatar
    Brighton
    678
    Mag or aluminum wheels?
    AMA #395 / AARONHERSH.COM / SCORPION EXO / Madmoto / MOTOREX / WICKED PHOTOS / GEARZY / Vortex / OGIO / Leo Vince / Galfer / Pilot / MotionPro / Chicken Hawk / ODI Grips
    "The faster I go the prettier the girls look" - Nicky Hayden
    Quote Originally Posted by DOUBLE A
    They won't fit your '09
    Brighton
    678
    Front wheels goes right in, its the rear spacers and brake caliper bracket that need a little convincing is all...
    Those look like the aluminum based on the shape of the spokes. The Mag are shaped a little differently.
    Feb 2013
    Royersford PA
    30
    They are aluminum. I've got a set of Mags coming but for 600's.
    Brighton
    678
    I'd offer 1K for the wheels, since they are not mags & for my application need changes i.e. 09 gsxr 1000. Let me know, thanks
    Feb 2013
    Royersford PA
    30
    Going to hold on that for a little but do appreciate the offer.
  1. F/S: 09 ZX6R Race Bike - LOADED!!! ***SOLD***
    By 1000RR in forum Bikes For Sale
    Last Post: August 26th, 2013, 06:13 AM
  2. 2007 GSXR 1000 Street Bike
    By Cornfd in forum Bikes For Sale
    Last Post: June 24th, 2013, 08:59 AM
  3. Tons of part for sale, 08 GSXR 750 and O8 GSXR 1000
    By clowe in forum Parts For Sale
    Last Post: March 2nd, 2011, 01:26 PM
  4. 2006 GSXR 1000 Race Bike sold
    By jplracing in forum Bikes For Sale
    Last Post: August 5th, 2010, 08:29 AM
  5. GSXR 600 LOADED
    By KHABBAM in forum Bikes For Sale
    Last Post: November 26th, 2009, 07:34 AM
