Results 1 to 6 of 6
Thread: 1st gen SV650 rear wheel dimensions between spacers
    1,199
    I am looking for the length from either one axle spacer (bake side) to the other side (cush drive) for a 1st gen SV650 or the hub bearing from left to right.
    I have a 2nd gen rear wheel here and it is around 8-10mm too wide for this project bike I am playing with. I know the cush drives are the same for both years but are not sure about hub/bearing width.
    I can have a 2nd gen wheel/cush drive, brake caliper machined down easy enough, but I have to buy a wheel (my wife wont let me use her SV650 wheel :? ) so if a 1st gen works better so be it. I dont want to use the torque arm brake caliper so either way it will have the 2nd gen brakes on it.
    TIA
    Aaron
    Member Amateur
    Apr 2011
    United States
    61
    1st gen wheel dimensions
    If you haven't posted this question at TWF racing, an SV racing site, http://www.twfracing.com/vbforums/forum.php I recommend that you do. Zoran is the moderator and knows a lot about SVs. I have a 2nd gen, 2004, and I bought wheel spacers from him in order to convert to a 5inch rear wheel so I could use a bigger tire. He has a conversion for a 1st gen if you want a 5inch tire. Hope this helps.
    1,199
    Ok cool thanks I will do, the SV wheel will actually be going in a smaller chassis/swing arm so it needs to be 8-10mm narrower not wider :wink:
    NoBoCo
    547
    I'm measuring just under 117mm from bearing surface to surface with spacer & cush removed.
    1,199
    Cheers thanks Geoff!
    1,199
    First gen wheel is basically the same, on to plan B
  1. Gen 1 (1999-2002) SV650 Rear Wheel
    By gsnyder828 in forum Parts For Sale
    Last Post: June 18th, 2011, 01:57 PM
  2. WTB - 03+ SV650 Rear Wheel
    By gsnyder828 in forum Wanted!
    Last Post: June 5th, 2011, 03:52 PM
  3. WTB - 03+ SV650 Rear Wheel
    By gsnyder828 in forum Bikes For Sale
    Last Post: June 5th, 2011, 03:44 PM
  4. Gen 1 (1999-2002) SV650 Rear Wheel
    Last Post: June 5th, 2011, 03:39 PM
  5. GSXR wheel set with rotors, cush, spacers, rear axel
    By giovannir6 in forum Parts For Sale
    Last Post: September 16th, 2008, 03:19 PM
