96-99 Full motor engine. $800
Gas tank petrol $80
Right clip on $25
Left clip on $25
Swing arm $50
Stock gauges cluster $80
Rear master cylinder with rear caliper $60
Voltage regulator $20
Ignition switch $20
Rear wheel w/crush drive $100
Upper Triple tree $50
Front whell $200
Radiator w/fan and hoses $150
Air box $45
Gas fuel line hose $15
Stock rear shock $25
Front caliper w/lines $100
Rear subframe (racing) $30
Faring stay bracket $80
Front forks w/showa internals & lower triple tree $150
Main Frame $500
Front axle $15
Rear axle 20
Rear shock linkage $25
Fuel pump RARE 200
Full set off wheels $300
Rear set left $50
Rear set right $50
Coalant reservoir tank $25
Front brake master cylinder w/lever $50
Clutch lever assembli perch w/ switch $30
Battery tray box $20
Ignition coil $50
Throttle tub w/ grip $20
ECU cdi computer box $100
Starter $80
Arrow full race System $300
