does anybody have the 30mm (the bigger of the two used for the adjuster nuts) honda lock nut adjuster wrench that you use to loosen the adjuster nut with the 4 grooves in it on the swingarm after you remove the actual swingarm nut and bolt? i've ordered it from honda, but they don't do air frieght for tools (dumb) and it will take 10 days to get. i need to swap a motor before that so i'm seeing if anybody has the tool that i could borrow (trade for some beer?) to use in the mean time.
thanks!
mike-
update: made one with a grinder for the smaller one and bought the bigger one from honda.
