Results 1 to 3 of 3
Thread: Master Link
    Senior Member Amateur
    Feb 2009
    Boulder, CO
    106
    Master Link
    Background: About a month back, my FZR threw its chain on Wadsworth. It was due to a stripped countershaft nut that allowed the sprocked to get out of line and jump the chain. I got another countershaft nut from the junkyard and torqued it down to 55 lb-ft, so that problem is finished.
    The chain broke at the clip style 530 o-ring master link. I inspected the chain... hardly a scratch, so I figured I'd slap another master link in it and run it.
    First master link, bought from dealership, was a 530 clip style link, non o-ring type. It fit through the hole but it was not wide enough. Ok, my bad.
    Second master link was o-ring but rivet style. Had to buy an $80 rivet tool. I now get around to trying to install it and find that it doesn't fit in my chain. I pull out the calipers and find the second 530 master link pins to be .204", the first 530 master link pins to be .199", and the pin holes in my chain to be .203". Chain holes grow with wear, not shrink.
    Am I missing another set of criteria for getting the right master link, like o-ring, clip style, roller chain master link? Or do the manufacturers change stupid little specs like the pin size to make you buy shit you don't need.
    I just want to return the $80 tool, return the two master links that dont fit my chain, get my money back and get what I wanted in the first place, an o-ring clip style roller chain master link.
    2021 MRA Race Director
    MRA Cornerworker 2009-2014, 2020
    Equipment Manager, Crash Cart, & Mobile Responder in there at times
    EX250 Track Day Enthusiast & RMMM KX65 Racer 2020
    Senior Member Expert
    Apr 2005
    1,829
    Hi Marshall,
    Yes manufacturers do and you would be surprized at all the different specs they have. short of knowing the specific Chain brand you may still have a difficult time. If you find it let me know and you can use me rivet tool I'm in Boulder as I believe you still are and can be reached at 720-841-6020
    Best of luck
    Jon G
    Apr 2005
    1,829
    Hi Marshall,
    Best of luck
    Jon G
Similar Threads
  1. MRA Link on soonerbillz.com
    By Louden in forum MRA Marketing & PR
    Last Post: June 2nd, 2013, 04:59 PM
  2. SuperStreet info link??
    By Jim 'smooth' Brewer in forum General Discussion
    Last Post: February 21st, 2011, 08:14 AM
  3. Fox News Link
    By Racing616 in forum General Discussion
    Last Post: August 11th, 2009, 09:43 PM
  4. PMP Schedule Link
    By Vanmar Racing in forum General Discussion
    Last Post: September 5th, 2008, 09:25 AM
  5. NEW LINK FOR PMP SCHEDULE
    By Earlene in forum General Discussion
    Last Post: August 29th, 2008, 11:49 PM
