Results 1 to 10 of 10
Thread: safety wiring drill bits?
    Sep 2011
    104
    I've been trying to drill and safety wire a 250 I recently picked up. I've tried a couple different types of bits but they all suck. They typically make it through one bolt and its done. Any suggestions on the type of drill bit to use and where to get them?
    Hard steel bits from ace.
    Sep 2011
    149
    Snap-On thunderbits. I did my entire bike with only 3. Would have been one but I knocked over the drill and snapped 2 in half. They run about 3 dollars a bit.
    MRA Novice #215
    2009 ZX6R
    Gebhardt VW
    Mar 2007
    the blu-mol bits at home depot are by far the best ones i've found for safety wiring. last hpr race one bit was passed around to 2-3 different people and was still sharp as ever and never broke when using the technique below.
    the key is drilling at the slowest speed possible with medium pressure until right before the bit is about to break through the other side of the bolt. if you keep going slow with medium pressure the bit usually binds and snaps as it breaks through. right before the bit is about to break through, try speeding up the drill a bunch and going with super light pressure and it will go through without binding and snapping. i've used a single blu-mol bit on at least 10 bolts using this method. takes some patience to go slow but you'll get through the bolts faster with a super slow drill speed.
    Apr 2008
    EARF
    666
    If you can find true titanium bit sets they will last you for the rest of your life...not the fake bs one Home Depot sells but real titanium... My Grandfather gave me his set that will drill through easy outs like butter...let alone bolts.
    If you are not braking them google how to resharpen them...takes about 5 seconds on a belt sander....
    Lifetime novice.... #969
    l ______
    /l ,[____],
    l---L -[]lllllll[]-
    ()_) ()_)----)_)
    Using some cutting oil on the bits helps them last longer and work better too
    Are you using a drill or drill press? The press is much better....and I have one.
    Sep 2011
    104
    I don't have a press. I'm using a drill and a vise. I just picked up some cobalt bit and I'll see how they do later. I tried using the one's from Home Depot, both the Titanium and a cobalt one. Both failed! I picked up some oil too.
    My press is portable, you are more than welcome to borrow it, or bring the bolts over and I will drink beer and watch you work.
    Jan 2010
    50
    Quote Originally Posted by jmaher
    :lol:
    MRA back marker extraordinaire #305!
  1. Wiring Harness?
    By sneeky in forum Rules & Tech
    Last Post: June 25th, 2013, 11:06 PM
  2. Brake bits and pieces - FREE
    By Mark669 in forum Parts For Sale
    Last Post: July 29th, 2009, 08:09 AM
  3. Safety wiring question
    By BrandNelson in forum Rules & Tech
    Last Post: March 31st, 2009, 11:59 PM
  4. PPIR Tid bits
    By bluedevil in forum General Discussion
    Last Post: September 11th, 2008, 04:10 PM
  5. CRF250 Supermoto bits
    By Filo in forum Wanted!
    Last Post: June 28th, 2006, 01:10 PM
