Results 1 to 14 of 14
Thread: 675 needs new clutch, anyone used EBC or Barnett?
    Apr 2009
    Castle Rock, CO
    304
    Sunday my stock clutch finally gave up the ghost after a couple years of abuse from my slipper clutch. It was slipping so bad the bike sounded like a scooter going down the back straight, so time for some new fibers. Curious if anyone has experience with the Barnett or EBC kits?
    The EBC is much cheaper and is just the fibers, but I was worried as they say they are aluminum-impregnated cork. Seems to me putting aluminum dust in there just adds to oil contamination, anyone know if the Barnett uses this as well? The stock plates are like $220, so one of the aftermarket seems like a better way to go, suggestions?
    #91 Triumph 675
    Thanks to: Motowheels, Woodcraft, Cogent Dynamics, Toyota, and Nikkie
    Apr 2009
    104
    Are you running synthetic oil? I was told by some pretty reliable sources to use nothing but stock clutch plates if using synthetic and a slipper. Some folks on 675.net had tried other then stock and had slipping issues.
    I know I am past due for a refresh on my clutch. Maybe we can get a "buy one get one free: deal somewhere :lol:
    MRA #888 Triumph 675.
    Apr 2009
    Castle Rock, CO
    304
    I was hoping to avoid paying the ridiculous price for the OEM ones, but yes I run full synthetic and a slipper clutch. Thanks for the input, anyone else?
    #91 Triumph 675
    Jun 2010
    315
    I only have one weekend on my EBC clutch fibers so I can't say I have an extensive record with it, but it was a big improvement over the fibers that were going out. I too have a slipper, started running full synthetic just this season, and the launches were vastly different / improved. I'd hardly call it a testimonial, but wanted to throw in my $0.02 since I just went through this.
    Jamie
    MRA #88
    647
    Hey Sam. I have 13 race weekends on my stock frictions and plates. They look Brand New. Serious there is not even a shadow of wear on the plates, and the frictions are exactly new thickness spec. They worked awesome in my slipper all year last year, and felt great last weekend back in my stock clutch setup. I also use Mobil 1 4t synthetic moto oil, and launch at 4200rpm every race, and usually spend the first few corners in a podium position.
    I had a friend install some EBC frictions in his stock R6 slipper last weekend, and they were not slipping at all because they seem to have a slightly thicker specified thickness. They were not shifting or launching very predictably either because of the different friction material still needing to flatten up to the steel plates completely. I would recommend the stock friction. I believe you can only get the friction plates and steel plates as a set from Triumph. I think it may still be the best value in the long run though.
    You were still flying out there, and I hope to get to bang some bars with you at PPIR buddy! Good luck. Hit me up any time. We also got some tire stuff dialed last weekend that may be helpful to your wear situation. Later.
    HOT CARL! Expert sheispoison's Avatar
    Nov 2007
    537
    Hey Sam, I got told by the guy at EBC that their aftermarket clutch plates are great for street use, but for race use you should use OEM plates. I've been racing my bike for 4plus seasons and I've put two clutches in it. And that was before it wore out, I prob could've gone longer on it.
    http://wolfbrigade217.blogspot.com/
    2014 VP of Rules & Tech
    MRA#217
    Th'ink Tank Tattoo, The Walnut Room, Rocky Mountain Kawasaki, STM Suspension, Sol Performance, Pirelli, Speedmetal, BloodNickel, MadMoto, Puma, Woodcraft, Armor Bodies, VonZipper, and
    Lacy
    Apr 2009
    Castle Rock, CO
    304
    Thanks guys, sounds like I need to track down an OEM set. The clutch had about 5000 street miles on it and I swapped it over to the slipper two full seasons ago so it had a good life.
    Dennis, I think the Pirellis I was running needed more PSI, will keep working on the setup also and get something going. I wasn't going to run PPIR but I might be getting coaxed into it.
    #91 Triumph 675
    Nov 2007
    537
    Sam, you better bring your ass down to Pikes!
    MRA#217
    Lacy
    Denver
    4,077
    Quote Originally Posted by sheispoison
    It would be kinda awkward if the rest of him didn't come too?
    Nov 2007
    537
    Quote Originally Posted by dave.gallant
    Yes Dave. Yes it would. :roll:
    Sam, I wish you would've said something durring the weekend. I have a used set of plates in my spares that would have got you through the weekend. On another note, you can order just frictions from the Triumph dealer (caugh, Foothills, caugh), I just did at the start of the season and replaced just the frictions and the cover gasket.
    MRA#217
    Lacy
    Apr 2009
    Castle Rock, CO
    304
    Carl, no worries it didn't start really slipping until during AM-U and I wouldn't have had time to change them before T-Bike anyways. My video from Thunderbike is funny, I come out of the corkscrew and the revs peg then they drop as I ride up the hill. Luckily it wasn't enough to leave me stranded, just enough to give really crappy drive out of corners!
    I'll talk to my ass about PPIR and see what it says...
    #91 Triumph 675
    Senior Member Expert marty's Avatar
    Dec 2006
    arvada, co
    596
    If that van is a rockin', don't come a knockin' :lol:
    RS 125
    TZ 250
    #738
    647
    We thought more psi a few times, but didn't see what we wanted to see. When I finally dropped the pressure quite a bit they really started working good. I found Carl was running similar pressures to the ones I ended up with also. We WILL see you at PPIR. Let me know if you need to media blast your steel plates to clean them up from a little slippage.
    In the Pegram racing semi trailer
    1,029
    stock clutches are all we will race on
  1. 03 R1 SLIPPER CLUTCH
    By JohnGarc in forum Wanted!
    Last Post: June 23rd, 2010, 07:46 AM
  2. Yoyodyne Slipper Clutch and Clutch Pack
    By Munch in forum Parts For Sale
    Last Post: November 10th, 2009, 08:45 PM
  3. R6 Slipper Clutch - NIB
    By jbird in forum Parts For Sale
    Last Post: June 1st, 2009, 09:08 AM
  4. Clutch Plates
    By froth in forum General Discussion
    Last Post: October 9th, 2007, 07:53 PM
  5. clutch
    By Phat-X in forum Wanted!
    Last Post: May 31st, 2006, 10:18 PM
